Wishlist: Adjustable home values for each sub
It would be great if I could set a home value for each sub, especially for Effect Subs. That way when I hit Sub 1 Thru Home, everything goes where I want it, instead of to 0.
  • We've been discussing various methods of addressing this kind of issue. I "think" the current idea is to use the OFF command such that when you OFF a range of subs they turn off but any faders that are just doing mastering work wouldn't move.
    So if you have an Effects Sub or an IM sub that is just Mastering the output level "Offing" it would kill the output but not touch the handle position. This would be combined with expanding the idea that the Fader Handle could just master output - not execute it.
    How does that sound? I "think" I like that better than setting a static Home position.
