FIXTURE PROFILEs NEED UPDATING. Elation Plat beam 5r Pro, Elation SixPar 100
Afternoon, The following fixture profiles need a correction:
Elation Platinum Beam 5r Pro, Ext. MODE.  Prism Speed is Not Shown (Currently its Prism on or off with no speed control)
Elation SixPar 100. All Modes.  RGBWAUV is not operating properly.  Amber and White is Stuck at Full and only dims will intensity.  Red Green Blue UV seam to dim properly.
Should be it.
Thanks - Aaron
  • Hello, Aaron:
    Do you know which software version you are running?  This can be found by clearing your command line and pressing [About].
    For the Elation Platinum Beam 5R it appears I can change the Prism by using the Beam FX Select.  Is this category not present for you?
    For the Elation SixPar100, how are you attempting to change the color?  I was able to move encoders and change them, and they also appear to be effected by the XY color picker.
    Thank you,
