I've been given a set of LED wash/beam lights to use on a cued show and I've found an odd behaviour with the Rem Dim function. If I create a cue with the washes in and want to tweak their focus position I can use the following command: Chan 211 [Rem Dim] [Enter], and I can user the mouse to adjust the focus position in the moving light control section of the display. When I'm done I then press [Rem Dim][Enter] and all other lamps return to their recorded level. However, if when I Rem Dim a wash light I adjust both its focus position and its zoom, when I press [Rem Dim][Enter] again everything except the wash I selected stays at 0%!
Is this meant to happen, or I am not typing the correct commands? I'm using an Element 60/250 which is running version 2.2.1 of the software, and the wash lights are Prolights Reflexes.
