direct selects request
I'm loving how much the direct selects x25 can be customized with 2.3
It would be more convenient though, if the config menu had page up and page down buttons to set which page you wanted.  If you have both the arrow and page buttons turned off (in order to fit as many DS as you can in the available space), it's a bit of a pain while configuring the layout to then get it set to the right page.
Also, it would be great if we could someday down the road get workspace layouts with 6 frames (or even 8).  With larger external monitors, there's plenty of room for more frames; particularly with the DSx25 only displaying one type of DS.
Actually, even within the constraints of 4 frames, there is another layout that would be helpful.  Picture it as 3 horizontal frames, one on top of the other, with a vertical frame to the right of those three.  And, of course, there'd be another version with the vertical frame to the left of the other 3.  The 3 frames are perfect for DS in rows of ten, and the 4th frame lets you utilize the extra screen space.
Kris
