Would be great to have another option for spreadsheet in blind which shows only the cues in which a channel changes level - therefore condensing the existing spreadsheet down to only show you the cue number line of the channel/channels you have selected. This is very similar to the MA Tracking Sheet.
For instance; Channel 1 has a scroller and is at Full from Q1 thru to Q11, it is in o/w in Q1 and changes to #372 in Q5 and then to L200 in Q10. The Spread sheet will only show you Q1, Q5, and Q10. This would work for all parameters currently selected.
Max
