Configuring Manual Control Up time breaks Next-ing through RemDim'd channel selection
I mentioned the following before at the tail end of a separate thread in the main forum, but didn't see any response at that time. It's still a problem as of 2.3.3 build 6, so just want to make sure it has been captured
- Manual Control Up time set to 4 seconds in Setup
- Apply RemDim to a channel selection (e.g 65 Thru 70 RemDim Enter)
- [Next] through that selection => rather than each channel in the selection coming up in sequence, three or four channels come up each time I click Next, e.g.
... 1st Next - just 65 is at cue level (as expected)
... 2nd Next - just 66 is at cue level (but snaps)
... 3rd Next - 67 through 70 all fade to their cue level together
... 4th Next - 67, 69, 70 go out, 68 stays on, 66 fades in
... 5th Next - 66, 68 go out, the other 4 channels fade in to their cue level
... etc, etc..
After removing Manual Control Up time in set-up, and the Next behaivour above returns to normal (one light at a time).
