I just received a new ION based on Windows 7 instead of the older XP version which I've been using for quite some time (we have 3 across different campuses).
Using the keyboard provided, I am unable to type in commands normally with every key being locked to a shortcut regardless of whether scroll lock is on or not.
Was the ability to use a keyboard to type "Thru" instead of just "T" and Ion replacing it with "Thru" removed? Is there a setting to allow me to change the keyboard back to an actual keyboard instead of a bunch of hot keys and if so, where?
Since I have a lot of other responsibilities and can type quite fast I have never taken the time to learn the shortcut key mapping and I can't say I want to or have the time to learn them now. If I wanted to use one key to execute a command I would just use the keys on the surface itself (which I also haven't memorized). It will severely slow me down when programming to have to stop and learn where each command is located.
