Bug: changing Shutter parameters blanks the right monitor
When live table view is expanded across monitors, changing Shutter parameters sometimes makes the right-most monitor blank
  • John, are you still seeing this?  I assume the monitor that is blanking out has the live table on it and not some other view?  Are you changing the shutters from encoders, from virtual controls or from the command line? What hardware are you on?
    Thanks much.
    anne
  • I don't remember well but I was using an Ion at the ETC office. If I recall correctly, I had the CIA on the right monitor and one frame on each monitor and I used the Expand key to extend the live table from the left monitor to the right monitor and I don't think the entire monitor was blank, only the contents of the frame. That's about all I can remember.
  • It doesn't actually make the monitor blank.
    I set up the left monitor with one frame of Live Table and expanded it right.
    I was able to select shutter data using the mouse on the right monitor, change that data, and it occasionally scrolls the view all the way over, by itself, leaving the right monitor empty of data. I am having a hard time reproducing the behavior.
