In patch when changing format doesn't hold selection anymore.
I've realized since upgrading to 2.3.x that a feature I used to use seems to not work anymore. It used to be that I could be in patch by channel, select a channel, press format, and then have that address selected still. It also used to work the other way to be in patch by address, select an address, press format, and have that channel selected. We used to use it all the time for things like "what used to be in chan 240 make chan 860" or just referencing ranges of dimmers like: "we know the dimmer in chan 3 is correct, where is there a dimmer next to that one that's used and patched wrong?"
I don't know if it was a bug that existed that I was exploiting and is now "fixed" or if this is now the bug where this feature doesn't exist. Either way, I liked it and I miss it.
