Effect on submasters when in cue ..... Please help
I wonder if some one could answer this query? Using the latest software 2.3.3 on an etc ion I have 4 spot movers in the rig and are in a gobo and focused etc with the intensity at 100% The query I have is that if I have an absolute effect on a fader as effect sub and intensity master how can I get it to over ride what is in the cue I have the following absolute effect, Action 1 time 0 dwell 0.5 level 100% Action 2 time 0 dwell 0.5 level 0% My movers in the cue stack are at full already but in previous versions of the software I have been able to override this particular effect in a cue All circle effects on faders are fine it seems to be just the level on absolute My 2nd query is, If I run an step bases or absolute effect in a cue i.e. Steps 1 and 2 all blues 100% and then reds 100% and the same with absolute effect on generic lamps, when the cue is running with the effect, when I put subs that have these channels in up to full this should take preference and put them up to full even though the effect is running in cue, in this version of the software this doesn't happen it takes no effect ........ Help please
