MS + DS submaster behaviour
Hi, I use a GIO and an ION in a cross platform venue and I do a lot of one night shows, hence a boat load of busking.
I've taken to using a fader page per song and I use a lot of magic sheets to get around and build/update content at speed over sound checks etc . . .
So I have a lot of pre-built content and I have a magic sheet with buttons to select subs so that i can populate the pages as I go.
I've currently had to write a macro per sub that just says SUB [X] as a magic sheet object only seems to bump the sub, as does the direct select.
So I've wrote off 1000 macros to do the job, and another 1000 for playback as the magic sheet object goes to cue (all I want is it to post CUE [X] to the command line so I can put it on a fader but can't figure a more economical way.
Maybe I'm missing something though...
