not displayed channels in 2.3.3
There is a display error in version 2.3.3.
If I switch the display to active channels and go without scroll on down, some channels are not visible. Even if I select the channel it is not visible. Only when I scroll with scroll on I can make the channel visible.
I use a 16: 9 monitor and one row of channels appears to be outside of the visual range.
Greetings
Chris
