Would be nice to be able to invert parameters other than pan and tilt.
Specifically Iris
Specifically Iris
Be a bit careful: if you edit the fixture profile you may lose the color calibration data. This can make recalling color data dicy. Furthermore, this fixture type will now (obviously) not work with your existing by-type palettes in old showfiles. Just make sure to test it before you use it on a show.
