XP Ion 1k running 2.3.3 with Net 3 distribution.
When I'm turning on the system for the first time post-hang I like to bring up every possible address at a glow just to make sure that every fixture hung is funcitoning before I start to locate dimmers. I run a system with dimmers on multiple universes and thus try to use this syntax:
Address 1/1 thru 512 + 2/401 thru 2/500 + 5/1 thru 5/48 @ 30 enter
What usually happens is that Universe 1 and sometimes U2 will output but my racks on U5 will not output at all, however, they are fully functional as I can go through and then park those addresses on following the first command.
Even stranger, when I reverse the syntax none of universe 1 will turn on.
As I'm writing this I'm realizing that I may be going over on allowed outputs, which would make sense, however I'm seeing entire universes that won't output. Is this what's happening here?
PJ
