Show File Archive
Is there a way to copy the contents of the Show File Archive onto a USB key short of opening each file and resaving it onto the USB drive?  With multiple boards in multiple spaces, I've love to be able to backup all the show files to a common location on a regular basis both as a secondary backup as well as a teaching tool / reference for future shows.
On that same note, is there a way to have the console automatically save a backup copy of the show to the USB key whenever the show file is written to?  Try as I might to get students to save to both on a regular basis, it never quite seems to happen.
  • Hello, you can in fact copy the entire contents of the Show Archive to an external device, it is done in the shell. At the logon screen if you goto settings/maintenance/backup show archive. Also note that you can restore a bunch of show files in the same place.
    Right now I don't believe there is a way to copy to both when you save. One of the things that I do is leave my computer on the network, with a client dongle. That way when a user saves it will put a copy of the show file onto it. If you have any Eos/Ion device that are working in the same system, again everytime you save a copy will go onto the hard drive of that device!
    Hope this helps!!!
    David
  • Thanks - I knew it must be in there somewhere!
