Ion vs Chroma Q scrollers
I have the old Chroma Q scrollers and when the Ion is in the mix the scrollers twitch uncontrollably. When the Express is in no twitching. I've turned off the RDM and I've slowed down the DMX and neither help. The scrollers are patched 1-1.
Any suggestions would be SO appreciated.
  • What personality are you using for your scrollers? I have found using a generic "Scroller" works best.
    Other Chroma Q profiles can cause problems if they aren't exactly the right profile. It sounds like your scrollers might be accidentally set in Gel Save Mode, this moves the gel back and forth across the lens so that no one part gets too hot.
    This mode will only work with gel strings made for it (with a wider cut of gel for each colour). A regular colour scroll would seem to be twitching back and forth if it combined with the wrong profile and set Gel Save Mode.
