Greetings All,
I have an Ion running 2.3.3.9.
Once the desk is set up and loaded in Rep Plot, I have had a persistant problem of one operator changing patch to suit his needs and never marking it down. He also reprograms submasters, again never leaving notes.
I realize that this can be solved by re-loading my show file, however, I would like to know if there is a way of stopping him from making these patch changes in the first place or restricting access so he cannot change the first fader page of sub masters? I have offered several options of giving him his own fader page to modify, or running his own showfile, but nothing seems to stop his insistance on changing things around.
As you can imagine this is a frustrating situation when you don't know what has changed and the loaded show in the desk is not how you left it, with no notes.
Please help me find a solution to keep the console in some sort of restricted playback mode allowing for all operators to access cues, run subs, record cues if needed, but not make any lasting changes that make it impossible for fellow operators to use the console?
Thanks in Advance,
Rob
