I have started using playback faders for busking movers on an Ion and there are a few things that have left me scratching my head - Any help is appreciated.
What is the logic behind which assigned number corresponds to which cue list? When I am in the fader controls set up - I would assume creating a playback fader and assigning it #1 would attach it to cue list 1 - but it doesn't seem to work that way. Assigning a fader as #0 attaches it to list 2 - what's that about?
Is it possible to disable the Q0 function when backing up a cue list before Q1 - Can I have the cue list loop backward to the final cue of the list instead? I know I can link the last cue to the first but there doesn't seem to be an option for the reverse.
Also a strange link behavior I have noticed - When the final Q in my list links back to Q1, it seems to clear everything in my current programmer. If I use the wheel to dial channels 1-10 up to full, when my link in cuelist 2 executes, it clears the intensities of channels 1-10, even though cue list 2 never uses channels 1-10 anywhere. Is this an intentional behavior?
I am admittedly not on the latest firmware (I am on 2.2.0) - I will attempt an update once this week's show has wrapped.
Cheers
