Hi there,
A couple of quick queries.
I am trying to build a magic sheet that is a custom preset view - i.e. grouping by Scene, scene labels etc. Just generally a bit more controlled than a Direct Select Window.
In the Direct Select view the preset labels wrap and cut to suit the box. Using the Preset button in Magic Sheets, and then retargetting the first field to be the Preset Label, this text does not wrap in the same way, so i have multiple overlapping labels ?
Is there a way to make the Magic Sheet button labels behave in the same way as the direct selects ? or do I need to rename all my presets .... ?
Thank You
James
P.S. Whilst I am here, has anyone found a way of protecting against double Go - for example pressing Go disables the button for a second or something ?
P.P.S. Apart from the Timecode workaround, there isn't a way of displaying a stopwatch easily is there ?
P.P.P.S. I would really love a way of customising playback status - for example to give a particular colour flag to a cue part which is for Marks, or for Haze, or similar. As the console has made such strides towards customisation of so many views, this seems one that has barely changed in years ....
