Exclude parameter from Highlight
Is there a way to stop a parameter 'highlighting'? I'm using some Source 4 revolutions with scrollers on the front, and it's a pain when I need to highlight one as the scroll whizzes all the way back to frame 1! (Which in a 22 frame scroll not only take a while, but looks pretty untidy). I realise that you'd usually want colour to go open when highlighting, and that's all well and good for a cmy/rgb wheel fixture, but a bit rubbish for something with a scroller on.
I know you can set up a highlight preset, but as I never know which frame the scroll will be in, there's no point putting it into one!
  • The way to do it is the Highlight Preset!
    Just put the intensity in there. As soon as you have at least one parameter of a Channel recorded in the Highlight Preset, all the other unrecorded parameters will remain unaffected by Highlight
  • That's great, thanks, and I can confirm it worked!
    The way the manual is worded, it didn't sound like that would be the case, maybe someone could reword this bit?
    If no highlight preset is established, or ***for channels that have no value stored in the highlight preset,
    the following values will be applied to channels as they are selected***:
    • Intensity - full
    • Focus parameters - no change from present state
    • Color parameters - home value
    • Shutter parameters - no change from present state
    • Image parameters - home value
    • Form parameters - no change from present state
    Ian
