Some problems with color effects, 910 and 914
Hey,
I have some problems with color effects or maybe I just don't understand them right.
  • If I make a linear effect with two or three colors as parameters, the colors run the effect at the same time. I would like to have them "phase shifted" like in the effect 910. Is there a way to control the phase shift of parameters inside an effect? Because even if the whole configuration looks like the one from 910, it doesn't do the same.
  • If I change effect 910 from three to two colors, the second color still starts after 1/3 of the time, not after 1/2 of the time. This way, 1/3 of the time the fixture has none of the two colors. Is it possible to change the phase shift of this effect or is it hard-coded somewhere?
  • Effect 914 doens't seem to work here. If I try to apply it to a fixture (RGBW LED) with "Chan 137 Effect 914" the console answers with "Error: No Channels Were Modified". The same happens if I select a group of these fixtures. I doesn't work like in the video tutorials.
