Please would it be possible to get this fixture made up so that i can have whole control over the 8 cells which can be effected by the effects please
Here is the user Manual: COLORbar_SMD_UM_Rev2_WO-1.pdfby the middle of september if that ok
Hello, James:
Eos thinks of each channel as a single fixture, controlling it as one unit. For this reason if you want to have individual cell control of this unit you will need to patch each cell as its own channel. In this case each cell could be patched as a Generic LED RGB 8b and you would be able to individually control them.
Thank you,
