Bumping this one, as I was asked to post here and never heard back:
First off, the backstory:
I'm running my hazer with an absolute effect triggering two different presets (one with haze at 05%, the other at 0%. Blower at 30% in both). This is recorded in my main cuelist. My HVAC is an untamed beast, and sometimes like to toy with me, so I've got an additive and a inhibitive sub to control just the haze parameter should things get too soupy. My additive sub simply has the haze parameter of my fixture at 100%.
The issue:
With the effect running from the cuelist (and only with the effect running, if the fixture has a hard value the issue isn't present) as soon as the sub hits 01%, the haze param jumps up to full. Regardless of sub position, it fades normally and proportionally to the subs downfade on the way out. This same issue is present for the same sub I've got for my blower. To reiterate, only with absolute effect running, and only on the upfade. Pre-2.4 I've used this configuration without issue. A friend has been able to recreate this issue offline with this description.
The deets
Console is running 2.4, problem sub is additive, proportional, HTP and runs the same priority as the cuelist.
Lemme know! I'd love to find out what I broke this time...
