2.4 Bugreport Nomad dongle not working on Mac
Nomad dongle + EOS Programming wing: I have updated to 2.4 and the latest firmware (ETC_HS_Driver_Update) as described in your Bulletin, but now I have two problems:
1. My wing is working on the mac (El Capitan), but the dongle is not recognised. I can only choose offline w/visualiser or offline editor. On the same machine using Windows 10 (via Bootcamp) there is no problem.
2. If I go to Setup>Desk Settings>Brightness setting and fade the Light levels faders up for Master and Backlight at some point I loose control (as if the wing is drawing too much power from the USB port)
I have tried to reinstall the software and to reload the firmware (with the windows 10 machine), but not to any result.
