Unexpected behavior using "Load" keyboard shortcut and multiple cue lists
I want to be able to load a cue from another cue list using the keyboard.
Running cues from List 1:
"Q 2 / 1" and the load button on the drop-down or virtual keyboard loads cue 2/1 so that when I press [go] it runs cue 2/1 and [go] runs the cues from List 2. Good.
"Q 2 / 1" and the Load shortcut "Control-Alt-L" gives a syntax error.
"Load" in this case should work the same as the load key on the virtual keyboard.
Control-alt-L BEFORE typing "Q 2 / 1" loads cue 2/1 to any virtual fader that already has cue list 2 mapped to it, which is fine, but it doesn't help me in this case.
