Loading cue info without intensities and plotting subs without moving lights attributes.
Is it possible to choose what information from a cue you want when loading a show file?
I basically want all the info except for the intensities so that I can start those from scratch (I.e so that tracking will still work).
Also (and I'm sure I could have googled this easily but as I'm here...)
How do you programme subs to not effect any ML attributes but still record the intensities they affect into a cue?
Cheers!!
you can't choose while loading a showfile, but you can easily remove the instensities after you loaded: Blind, Cue 1 Thru Enter, Chan 1 Thru 5000 Intensity At Enter.
regarding the sub: Chan 1 Intensity Record Sub 5 Enter
