sneaking a channel and updating a cue takes that channel out of the live cue.
Running 2.4.0 on ION and Nomad.
For example lets say I have channels 1-5 at a level in a recorded Q now I bring up some other channels in the same cue and change the levels of the first 5 channels but change my mind and sneak them to their recorded level and update the cue. I've noticed if i don't let the sneak finish and update the cue,"1-5 sneak enter update enter" the result is the channels I sneak are removed from the live cue. if I go into blind they are still in the blind cue and go to cue enter restores the channels in live but I feel like this shouldn't happen.
  • Clarifying here for curiosity: Are, the channels removed from live view in the live channel display, or is it also affecting actual dimmer outputs?? If you select those channels in live after the sneak and cue update (without going back to cue), and query absolute channel displays (holding down data key), are the values at 0? Does it happen if you specify the sneak time absolutely, ie: 1-5 sneak 5 enter update enter?. You certainly peaked my curiosity with this one..lol.
