When there is an effect running in two different cue lists with the same cue number it seems that you can only modify the attributes of one of the Effects running even though there are a handful different sources listed. I can go into blind and do each one individually, but it would be nice to modify them all in live and update all the lists respectively.
I'm also having an issue with effects not tracking properly at times and ignoring blocks. One situation that I've noticed is that if you update an effect change then undo that update and try to update again, it will not save. It just seems that Effects don't function properly involving tracking and just aren't doing what would be expected.
