Hi all. I have an ION master with laptop client. The client is with the SM for rehearsal so they can hit GO while I'm still plotting with the designer. The SM will be operating from the ION once in show mode. With the client in user 1, same as the console, the SM can hit the spacebar for GO, and control+spacebar for back. With the client set as user 2, so I can jump between live/blind without effecting his screen, GO works, but BACK doesn't.
I was informed via the facebook group that I need set a master cuelist on the client after setting it to User 2. This did fix the stop/back issue.
Is it normal or a bug for GO to work without a master cuelist set, but not STOP/BACK?
Cheers
Rob
