effects on submaster
Hello I am having trouble understanding effects on subs at the moment I can get the to record and I under stand i can press the bump key to start the effect and then put the fader up so the shutter opens. But if the mover is in home position it will start the effect there then when I put up the fader it shoots to where I recorded it.  Is there a way I can  press the bump key to move it to postion and start the effect then just use the fader to open to shutter. ? Or am I doing something wrong in the recording of the subs should I be using record only .?
console etc ion latest software with fader wing
