You should be able to move the active tab by holding down [Tab] and using the [RightArrow] key. Hitting [Tab] by itself will cycle through each active tab.
this does indeed cycle thru the screens but i'm unable to move the screens between the two displays - ie. i need a cue list on Screen 1 and the channel screen on Screen 2 - please note that thi issue is on the RVI not the main console or other clients
-Matthew
Probably best to call in for support - this should be easy to set up.
US +1 608 831 4116
UK +44 20 8896 1000
Or other numbers on the website!
-luke-
