At present you can't. The only workaround I can suggest is to write macros that post those commands to the command line, that way you can then access them from the RFR. Same goes for accessing pallets/presets
I didn't really expect that there would be an elegant solution. However, this is a bit cumbersome as not only do I have to use a macro I also have to enter a numeric value. Are there any future plans to make this work easier?
