Minor Bugs in 2.4 software
1. [Go to Cue] [x] [/] [Shift] [Home] [Enter]
"[Go to Cue] [x] [/] [Shift] [Home] [Enter] will take you to the last cue in a cue list."
- Doesn't work - I get "Error- Number out of range"
 Fixed
2. MS tab double-click
"The display tools for Magic Sheets are now available by either right clicking or double tapping on the Magic Sheet's tab." Double - clicking it doesn't work - it pops up the menu but the menu immediately goes away. Workaround: right-click or click on the gear icon in the tab bar.
Double-clicking works on the PSD or channel display tabs.
3. Bug: Inverting shutter order doesn't work
"Shutters can be reordered in the Patch {Attributes} page. . Press the {Shutter Order} button to open the shutter order display. The {Shutter Order} button will only display if a channel with shutters is currently selected. In this display, you can invert the shutter order or rotate the order using the arrow buttons. After you have created the order needed, press {Apply} for your changes to take effect."
Pressing {Invert order} doesn't actually invert the order. It rotates 180 degrees. I am unable to test the effect on an actual light.
