(Fixed) Bug: (Nomad) Master faders don't work when cue list is mapped to a virtual fader
This one completely screwed me while I was at work.
To reproduce:
Make sure Cue list 1 is mapped to master faders
[cue] 1/
then load to fader 1
Slide fader 1 to 0
Now the left fader on the master fader pair can't be raised above 0 - it doesn't affect levels and snaps back down to 0 as soon as I release it.
Even worse, I had unloaded fader 1 and so I wasn't aware that cue list 1 was at 0. I was trying to run cues and couldn't figure out why none of my levels would go above 0. I ended up copying the cues to a new cue list and running them from there.
I eventually figured it out - had to reload CL1 to a fader and set it to full.
ALL FADERS with the same record target should behave as one. It works as it should with two virtual faders that have the same record target.
(Obviously this won't work with a univeral fader wing but you get the point).
