Magic Sheet...is this possible?
I'm moving along in Magic Sheets, thanks to Daz and PB for the help. Now that I've gotten my BP all set up and labeled (including the pictorial gobo icons,) I've added below these a series of buttons that control rotation rate and direction (0%, 25%, 50%, 75% and 100%.) These are simply reference points of speed but, of course, you don't always rotate at specific rates so, with that in mind, I want to create a button or buttons next to each row of speeds that would allow me to vary the speed of rotation.
I've tried adding a console button with encoder as its target and another button with encoder wheel 4 as its target. When I grab a fixture, add a gobo, give it a rotation value from the BP buttons and push the encoder button all I get is the "encoder page" flash on the console and no control over the rate.
Is there a way to create a button or whatever that would give me a way to alter the speed as I would with the actual encoder wheel on the console?
I'm sure there's a magic macro that I can build and attach to a button on the MS but have yet to figure it out.
Am I asking too much of my magic sheet? Should I simply resign myself to fact some things are best done from the console :)
Thanks in advance for any thoughts on this.
MOD NOTE: Moved from Eos Family Show Control to main Eos Family Forum
  • I am having zero luck with a macro to increase/decrease the rotation speed of the prism in my Elektralite LXE 700 fixtures. When I use the macro: select_last_params @ +01 Enter it accesses the function however it steps the parameter up 1 "effectmacro" of which there are 15.
    However, the fixture seems dead set on making me use the shift+encoder wheel in order to vary the speed of the prism faster or slower in either direction.
    I do have a series of beam pallet buttons that put in the prism, remove the prism, rotate it clockwise and counter-clockwise and stop rotation. These all work as they should.
    If anyone out there has any experience with the Elektralite fixtures and has sorted this out, I'd greatly appreciate anything that sends me in the right direction on this problem.
    Question: is it possible to copy a magic sheet view to another view, i.e.: MS 3/1 to MS 3/6 and have it editable? I've tried but when I scroll through my views what I've edited in one shows up in the other.
    I've tried copying it to a completely different magic sheet, i.e.: MS 3/1 to MS 4 and just shows up blank.
    What I'm trying to do is duplicate a view that has focus and color palettes on it so that I can make it a second page of those features. In page one, I want to make the final button in the array a macro that would access the second page (the duplicate page) and then do the opposite on that page that would send me back to the previous page.
    Doable?
    Thanks one and all.
