EOS to ADB show file conversion using ASCII
Hello,
Has anyone had any experience with porting a show file from an EOS to an ADB?  We’re trying to import an ASCII file from the EOS to the ADB.  Unfortunately as the ADB is a Cue Only desk and the EOS ASCII export only has tracked channel level values, the ADB ends up missing the tracked channel level values.  Is it possible to do an ASCII export from EOS that has all channel levels for all cues?
Any ideas much appreciated.
  • Hi Cookie-
    The Eos ASCII file should contain all of the channel levels for a cue, as well as a $$ manufacturer-specific tag to show the channel moves. For example, my cue 5 has channel 5 as a move, but 1-4 tracking:
    $$ChanMove 5@Hff
    Chan 1@Hff 2@Hff 3@Hff 4@Hff 5@Hff
    So I'm not sure why the ADB would read it? You could play with using percentages instead of hexadecimal levels in the export dialogue, which should give you this with the same example show:
    $$ChanMove 5@Hff
    Chan 1@100 2@100 3@100 4@100 5@100
    You could also try turning off the manufacturer-specific tags in the export, giving a rather more mundane:
    Cue 5 1
    Up 5
    Down 5
    Let us know what you find!
    Luke
  • Hi Luke,
    Thanks for the reply. On further investigation it appears to be something specific to my show file. I made a test show with 5 channels & 5 cues and all the tracking info appears in each cues when I view the ASCII file in a text reader:
    Cue 1 1
    Up 5
    Down 5
    Chan 1@50
    Cue 2 1
    Up 5
    Down 5
    Chan 1@50 2@50
    Cue 3 1
    Up 5
    Down 5
    Chan 1@50 2@50 3@50
    Cue 4 1
    Up 5
    Down 5
    Chan 1@50 2@50 3@50 4@50
    Cue 5 1
    Up 5
    Down 5
    Chan 1@50 2@50 3@50 4@50 5@50
    All appears as you would expect.
    But when I export the production show file, Cue 102 (Which should only take the house lights to half) shows only the house light channel level and not the tracked channels from cue 101:
    Cue 101 1
    Part 1
    Up 5
    Down 5
    Chan 75@50 84@61 85@61 86@61 87@61 88@61 90@70 91@50 92@50 93@50 95@45
    Chan 96@40 97@45 98@50 99@70 101@70 102@70 105@60 106@80 107@50 108@60
    Chan 109@60 111@40 112@100 114@100 115@90 116@100 213@100 214@100
    Chan 1000@100
    Part 20
    Up 0
    Down 0
    Text Act I Preset
    Cue 102 1
    Part 1
    Up 7
    Down 7
    Chan 1000@50
    Part 20
    Up 5
    Down 5
    Text House to half
    Any thoughts much appreciated.
    Cheers,
    Cookie
  • Hmmm, can you send me the showfile? luke.delwiche@ ...
  • OK, so just to draw a line under this thread and incase anyone else comes across the same problem, here’s what Luke kindly worked out for me:
    I was using empty Part 20 cues as Mark cues. (Just my preference to keep things tidy). When I did an ASCII export, the EOS seemed to have a conflict with the empty part cues and would only export changes in channel levels for all parts of those cues and not the tracked channel levels from previous cues.
    As we were moving to an ADB desk for the next residency, and the ADB does Marks in a different way, I deleted out the Part 20 cues and all the tracking information then exported fine.
