Unable to use subs on fader wing after deleting them
I am currently having the  problem of when i delete a sub from my fader wing the sub number disappears. Now i am no longer able to use the fader wing to control the subs and  only can bring them up from the subs page on the monitor . If anyone knows what is the problem is i have a show in a couple days and need it for then. Thank you.
  • this is an Eos/Gio/Ion question, right?
    there is a difference between a fader and a sub. a sub is a memory, somewhere hidden in the depth of the console, a fader is a mechanical tool to control stuff. if you delete a sub, then there is no memory anymore, thus the fader can't control anything.
    if you only want to get rid of the fader assignment, instead of deleting the sub you should use [Shift]+[Load] (on a universal fader wing pressing both buttons at the same time acts as load button).
    to re-instate/create a fader-sub-assignment, type [Sub][1][Load].
