In-console help errors
Hi there
The in-built help has a couple of little lies in it that I have noticed...
Negative Hang times:  Console help states that a negative hang time can be applied to a cue.  Currently this brings up a syntax error.  Is this an unimplemented feature or error in help?
Command Line Assert:  In-console help lists incorrect syntax.  From memory, it states the syntax should be [assert 4 thru 5 colour cue 1/5 enter].  I tried this and got a syntax error. However. [4 thru 5 colour assert cue 1/5 enter] does work.
Not sure if this was on your list or not, so thought i'd mention just in case  :-)
 Cheers
