Advanced patch merge doing more than we want.
Hello all,
During one of our shows we had to merge one channel to retrieve the scroller information. After that merge a different channel had changed its personality.
The channel that was changed is our Pandora's Box channel. We have a custom one for a few reasons and this was modified a bit more during this show.
The type name for this channel is the same over both files.
After merging the channel 931 to 9031 the definition for the pandora's box had changed. Something that we obviously do not want.
My questions are:
Why does merging a single channel import all favorites into your show.
Channels with the same type overwrite the parameters with data from the source show.
I can understand that the board overwrites it because the type name is the same. But if I do not select this channel/type for merge it should leave all of this alone.
Greetings,
Bart
