Hi All,
System Spec as follows:
EOS Classic running version 2.4.0.9.0.144 with Fixture Library Version 2.4.0.9.0.45, with a 4096 license. Running in a multi-console house as primary (Second desk on the network currently running as primary, other desk running 2.4.1)
If I try to load cue list 999 into the main fader playback, it doesn't work, and stops any subsequent loads from working. For example, If I attempt to load Cue List 1, it works, then I load cue list 999 and it doesn't, instead the playbacks are empty and the first cue in list 999 is selected, if I then try to load cue list 1 it fails again. Trying Go To Cue results in the error "No Playbacks Available". I have found a deep clear to resolve this problem but nothing else works (Including rebooting the desk).
Cheers All!
