Magic sheet object "command" as navigation?
Hi, couple of questions.
1. is there a better way of navigating magic sheets the way a background macro does? so that it doesn't interfere with the command line?
as my view numbers get larger and larger I feel like 1000 macros set aside to navigate my sheets is somewhat wasteful (not that I'm in danger of running out, but makes it harder to pass on to other users, you want these MS and all these macros to navigate) does that make sense?
I tried a command object that said
<U0>macro:Tab_Down 3 Tab_Up Magic_Sheet 1 View 1*
that worked fine on an emptyish showfile and was fine moving around views of 1 magic sheet, but when I tried it on my main file (I use about 12 MS's) it would open what would appear to be random views and random MS's (not quite random as the mistakes where consistent) and upon deleting <U0> from the command I could see it was firing the wrong command completely, very strange behaviour.
Maybe commands aren't meant for this, I don't know.
2. Is there any scope to having Cue Lists as Magic Sheet objects?
I'd like to reference my lists utilising the MS Label function but at the moment I can only reference the label of the 1st cue in any given list.
EOS Ti, GIO, ION x2, Nomad 512. all running V2.4.1
