Hello. I'm currently trying to set up a fader wing with effect subs. These subs contain movement effects which at my previous venue I was able to add time to enter and exit the movement effect. It would begin from a position pallet. Once pressing the asset button it would fade over the required time in to the moving effect which I have the sub controlling the speed. And then when pressing the assert button to stop the effect it would fade back to the position pallet over the required seconds. I was using Robe Colourspots 700's and this all worked fine. I am now trying to do the same on a brand new desk with the current firmware but now with chauvet rouge r2 spots. I now find when I press the assert button it fades to the position it would start the movement to but not be as fluid as I once had it and when I press the assert button to stop it fades to the position to where the lights stop moving and then snaps to final position. Instead of fading from moving to the focus pallet. Over the time required. What may I be doing wrong with the new fade confit or is there a setting in the desk I have wrong? Thanks
