Can someone help me out here?
When another operator loaded the default house show (patch and subs), the patch came in as a 1 to 1 (which is wrong). I'm going to think Operator error on this one. I Loaded the correct default patch, the normal patch came in.
However, all channels without an address assigned to them came up with a 0 where the level should be. Previously there was no 0.
The grey Channel number is present, there is no box around it, and a grey level # is present. In patch, the channel has no box around it, and nothing in the address column. The rows leading into the patch, database columns are black, not grey, and have no information (which is fine).
I would like to remove the 0 on all the unused channels. Anythoughts?
Thanks.
