Problems transferring one esf file from a computer running nomad to another.
I'm having problems transferring an esf file from one computer running nomad to another. Files are same, patch and cues imported correctly. But only half the lights are responsive on the second computer. The first computer runs the file correctly.
  • Is there anything distinguishing about the half that are working? For instance, if it's stopping at a particular channel then it might be a difference in licensed output counts. If the configuration has multiple DMX universes then there may be a difference in the way the ports are configured. If it's a certain fixture type then it might be different library versions. What does "About" have to say about the 2 systems and the channels that aren't working?
    More information would help.
