linear Effect - the time between the stepps
 Hiho,
i try to get more comfortable with creating effects, so i play a bit.
What i'm willing to do:
- A linear FX
- I snap to 100% and fade than out to 0%
If i use the graph to draw my fade-behavior and draw at all 4 quadrants, i end up of having a break between each step of the {Cycle Time}.
If i use the two quadrants, are next to each other, wich are sharing the positiv y-Achse, there is 0(Zero) time between the stepps.
This i what i found out... (spending 1hour of time)
Now the Question
W H Y  is it this way?
