Is the Shutter Graphic Tool also available on a Mac with EOSnomad? The described shortcut won't work. Backslash on mac is Shift + Alt + 7 and opens the Help. Working with a german keyboard layout on macOS sierra.
Gio Encoder Display 2017-02-06 08-34-00.esf
I'm thinking the issue could be that you need the Alt for the key command, but you also need it to make the '\' in German.
I will look into an SCR for this. In the meantime, I attached a showfile that just has a Macro 1000 that throws up the Gio Encoder Display. From there, you ought to be able to page through the options.
The macro works, thanks, for the moment I have also done a button on a magic sheet like ueli mentioned. It is not a problem of "use Shift as Eos Shift", I tested it. I attach for you screenshots for the german keyboard layout for mac (Macbook Pro 15'' with Sierra), maybe that will help you.
German Standard
German Shift
German Alt
German Alt+Shift
