Robe Robin MMX Spot M4 Encoder Bugs?
Not sure if anyone else is experiencing this.
When I push down on the encoder to pick Min or Max for Beam Fx Ind/Spd on the touchscreen, the channel clears from the command line.
Also selecting Min/Max for Beam Fx Ind/Spd, and turning the encoder on Animation Ind/Spd clears the channel as well.
After everyone of these selections I have use Select Last to continue to work on other parameters for this fixture.
However, I have no trouble with this if I use ML controls. Min, Max, Home and encoder on the ML screen appears to have no issue.
Regards,
Johnny
Gio 2k
v2.5.0
Fix Lib 2.5.0.9
