Feature Request: import magic sheet fixture coordinates into pixel map
NOTE: THE REQUEST BELOW WAS POINTED OUT AS AN EXISTING FEATURE ALREADY
It would save a great deal of time (and be much more aesthetically pleasing than doing by hand) to be able to do circular arrays of channels/objects in magic sheets. This would require a radius input and maybe arc length in addition to number of fixtures to add. Alternately, but maybe this is more complex, being able to "align to line/shape". So a circle or polyline can be drawn, and selected along with a group of channels, button hit, and they would at least roughly become aligned to the shape/line. A distribute sub-feature inside this would be fantastic.
THE REQUEST BELOW IS NOT HOWEVER, AND WOULD BE AWESOME
As well, many of the magic sheets I create are physical spatial-relationship representations of parts of the rig. Whether by hand or through features such as the above, once these magic sheets are created, it would be great to copy to a new sheet, take out any group or extraneous gack leaving just the channels in their location on the sheet, and when creating magic sheets, maybe add a button to "import channels from magic sheet.
Parents
  • Also, maybe it is a better solution from a software design standpoint to add a magic sheet creation tool that imports from your pixel map. So you would do the pixel map first, then copy it into your MS. Just an idea.
  • Yes, exactly. Possibly, the other way around. However, I find Magic Sheet creation quicker and easier with its numbering automation functions, and not all my shows have pixel maps, but all sure have magic sheets these days.
  • maybe you're doing magic sheets differently than i do? mine are never based on a grid with all objects in the perfect spot, their distances in scale and their size also perfect...
    i have a feeling that it would be too much guess work for the console?
  • Well, it depends on the gig. I agree, mine are also seldom direct reflections of the grid, usually more transitional theatre-LD-style magic sheets. But for some, like the one I'm on right now, in one area, I've got several large circular lighting positions of conventional and/or color fixtures, and my magic sheets for them basically look like big circles for ease of focus and channel/group-based programming. My pixel maps for them, which I use fairly actively for the show, are shaped the same way, but were a rather time-consuming pain to create, and they're basically copies of the channels on one of the magic sheet in the same orientation. So automating that would be awesome.
    I imagine it would require automatically scaling channel distribution from the maximum extents of channel location in the magic sheet to the total size of the pixel map. There would be some mathematical rounding and distribution based on number of channels vs pixels available for them, but it could also work great. At least it would be a good starting point, and pixel map size could be adjusted to allow for more space as necessary for a re-import.
    Also distribute channels along line/shape would also be awesome in magic sheet.
Reply
Children
No Data
