Temporary Rem-dim state using Next/Last?
Hello,
I don't think this should happen....
 "Channel 1 @ Full Rem Dim" then press "Next or Last" (which seems to let you cycle through the channels like highlight or channel-check does), if you hit "Clear" or start typing another command it clears the original Rem-dim command.
Hope that makes sense, using V2.5.1 b29
Max
