fixureprofile Bug: High End Systems SolaWash Pro 2000
Hello,
there is a bug in the profile for both color wheels. If you set the color wheel mode to continuos, the first color is Frame 1, the second is Frame 3, the third Frame 5 and so on. Between these there are Frames 2, 4, 6 and so on. Inside Frame 1, 3, 5 and so on you can fade as expected, but the Frames 2, 4, 6 jump to the DMX-Values 2, 4, 6 and so on. These means, if you fade from one color to another the wheel starts turning, than jump to white, and back again to proceed turning.
with best regards
Wanja
